Anonymous-0
IM working on an early model jd 3010 diesel. Tractor came in because the engine was breaking up at higher rpms and was smoking badly. I installed a new injection pump and had injectors rebuilt at an injection shop. THe reman pump has advance so I set timing at 4 degrees btdc. Engine ran smooth until the very peak of full throttle and would break up. It also was hard to start cold and smokes white/blueish smoke like crazy. I turned pump to almost 14 degrees btdc until i got her to run smooth at full throttle. Doesnt seem to be too bad now but is smoking blue at idle pretty good. Im going to let it sit outside tonight and check it in the morning. I also measured valve lift and found some exhaust lobe lift to be out more the 0.100 of an inch. I readjusted valves and got some of them a little better but I still have two over 0.100 out. COuld this be my problem here or could this reman pump be bad? Any info would be very helpfull.
