TractorLinks.com
Show Parts for Model:
Re: JD A Brakes
Randy K. Crump
02-21-2014 05:52:12
When you say "broken lining stacking up", do you mean the brake shoe lining is coming off inside the drum?
clampdaddy
02-21-2014 10:57:19
 Re: JD A Brakes in reply to Randy K. Crump, 02-21-2014 05:52:12
Randy K. Crump said: (quoted from post at 14:52:12 02/21/14) When you say "broken lining stacking up", do you mean the brake shoe lining is coming off inside the drum?
Yep. The brake not wanting to release makes me think that a broken piece of lining is getting wedged between the drum and another piece of lining that is still attached to the shoe. Basically causing a condition where the brake lining instantly becomes twice as thick as it should be. A broken lining could leave a bare spot on the shoe or an exposed rivet that could cause a grinding noise. Does it unstuck when you pit it in reverse?
This post was edited by clampdaddy at 11:05:53 02/21/14.
Randy K. Crump
02-22-2014 18:19:31
 Re: JD A Brakes in reply to clampdaddy, 02-21-2014 10:57:19
I don't need to put it in reverse to get it unstuck. All I do is pull the clutch in to stop the tractor then push the clutch out to begin moving again.
rla
02-21-2014 06:42:05
Yes that"s what he means. It"s either that or something else has cam apart inside the drum. You will not know till you remove the drum?
