Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: model A push rod sleeves
Pappy
02-20-2014 21:47:20
My book says the sleevs were used up to 487999.
Does not show any in the later parts lists.
RedJA
02-20-2014 22:21:04
 Re: model A push rod sleeves in reply to Pappy, 02-20-2014 21:47:20
Well I guess I'll be looking for a blown gasket, cracked block or head. Got a lot of water in the crankcase.
When I replace the head gasket should I soak it in oil like the manual says or is that just for the original type gasket?
Thanks for the info.
Mike M
02-21-2014 07:31:31
 Re: model A push rod sleeves in reply to RedJA, 02-20-2014 22:21:04
Look VERY close at the upper inside of the cylinder wall from about the top of the ring travel out. I've seen several split inside there and hard to see as it opens up when the stud nuts are torqued down.But this usually goes into the cylinders first.
