Deere 2630 Slow 3 Point Queston
Discovered that loader valve may be leaking internally--could this cause slow three point response? Once you turn steering wheel or activate loader, 3 point operates at normal speed. Already disconnected the valve return line to check for flow--checked out ok. Any advice / opinions appreciated.
Disconnect power steering line and cap hyd supply line where PS line attached then check loader speed. Also with 3 pt raised engine running look for spraying oil in hyd filler hole. How long since hyd filter was changed and sump screen checked? have you checked stand-by pressure lately?
