Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
4030 diesel timing pin hole
2stevewi
01-29-2014 15:41:06
Replacing the Injection Pump on brother-in-laws 4030. The Original one failed @ 13,000 hours. Of course it was 20 below outside. Trying to find the hole for the TDC pin. This a very early 4030, under 4000. According to JDparts.com the pin hole is just under the hole for the Flywheel Turning Tool. Checked his tractor, and cannot find a timing pin hole. Is there an alternate method of finding TDC on this tractor. Thanks Steve.
2stevewi
01-30-2014 17:11:38
 Re: 4030 diesel timing pin hole in reply to 2stevewi, 01-29-2014 15:41:06
Lined up the marks in the window on the injection pump. Found a mark on front pulley, that lined up with a mark on front cover behind pulley. Initially the mark was buried under a layer of dirt. Probably the same mark used to time a gas engine. Thanks for all the replies. Steve.
Tim S
01-30-2014 17:15:15
 Re: 4030 diesel timing pin hole in reply to 2stevewi, 01-30-2014 17:11:38
You did the right thing by finding the marks "before" you pulled the pump,,saved your self a lot of grief....
Tech 7
01-29-2014 16:28:47
I know its a gasser but the one I have torn down right now did not have a pin hole in the housing. Does have timing mark on crankshaft pulley I know this doesnt help you. This tractor is early (73) and I would wonder at Deere building the rear plate different for diesel or gas
Tim S
01-29-2014 16:33:05
 Re: 4030 diesel timing pin hole in reply to Tech 7, 01-29-2014 16:28:47
I'm kinda with you on that Tech7,,,it may not have a timing hole,, I always use the pump timing marks when I'm just doing a pump, and the cam marks when I'm doing an O/H....
Tx Jim
01-30-2014 03:51:19
 Re: 4030 diesel timing pin hole in reply to Tim S, 01-29-2014 16:33:05
According to JDparts the same flywheel housing(R51794) was utilized on both gasoline & diesel and only on a 4030 no other models
Tim S
01-29-2014 16:05:59
remove the timing window and rotate the engine till the marks line up is another way of doing it...
2stevewi
01-29-2014 16:12:56
 Re: 4030 diesel timing pin hole in reply to Tim S, 01-29-2014 16:05:59
That would be plan B. I was not sure if that would be accurate enough. Have replaced several injection pumps on John Deere's over the years, and this is the first one I have not been able to set at TDC.
Tx Jim
01-29-2014 15:44:26
Timing pin hole should be where plug(parts key #14) is located. There were no serial number breaks for the flywheel housing so all tractors should be similar to parts photo.
This post was edited by Tx Jim at 15:46:21 01/29/14.
