John Deere 50 entire gasket set (sets)
Looking for all gaskets to restore a John Deere 50.
Does anybody sell a complete John Deere gasket and seal kit (all seals and gaskets in one package) for restoring old two cylinder John Deere tractors?
Thanks for any info.
I've done a pile of complete JD tear downs and rebuilds and the best I could ever come up with was to order the 3 main sets from Deere,cyl. block and head,governor and transmission.There may even be a 4th for crankshaft replacement ? This still leaves a lot of gaskets to get separately and also all the seals. You also get several duplicate gaskets.
I bet by now maybe you can't even get those sets ? Many will have to be made. I always keep several thickness of gasket paper around too.
We're the best places to get good quality, quantity and the different sizes, thickness, and types of gaskets and seal from. What do you use to cut (make) the new gasket with.
Thank you
MikeNickandMatt
Our local NAPA usually has Victor material in stock. JV100 ( IIRC ?) is one part number I use a lot of.
CARQUEST should be able to get too.
Sometimes TSC had some rolls on the shelf too.
