Yesterday's Tractor Co. We Have the Tractor Parts You Need
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
what determins the length of the belt for running impliments
tugboattim
01-15-2014 05:09:00
75.148.17.149
hi all I have three deeres B/A/R and all have pullys for running thrashers/saw mills/buzz saws ect. I have a very short leather belt about 5 inches wide I figure that's for a buzz saw but any time I see a saw mill or trasher the belts about 10 inches wide and 10 times longer.is there a formula for sizing a belt for a sawmill thanks in advance tim
[Reply]   [No Email]
4020deereboy
01-15-2014 18:55:00
66.160.249.64
 Re: what determins the length of the belt for running impliments in reply to tugboattim, 01-15-2014 05:09:00
The operation care and repair of farm machinery has a lot of info on sizing belts. twenty fifth edition
[Reply]  [No Email]
Leroy
01-15-2014 09:31:03
69.88.207.185
You will not find a belt on a gas tractor that is wider than 6" as that was standard width of all the pulleys. The steamers used 8" belts. Never seen or heard of a 10" wide belt. Your pulleys will all measure 6" wide so that is a wide a belt as you can use. And that belt will transmit as much and more power than you have. Belts were made in different thickness for different power loads. For light power loads like the saw you can get by with smaller belts and a buzz saw could have been run with a 3 horse hit and miss engine. Length first consideration is how they can be setup as to location. A longer belt will give slightly more traction than a short bely but are harder to get tight. Mane reason for long belt on thresher was the steem engine used to power them and you wanted the fire for the steam and the sparks that resulted form the fire as far away from anything burnable as possible because if a spark would land in the straw everything would go up in flames and no fire departments at that time to try to put the fire out.
[Reply]  [No Email]
Gtx1967jewison
01-15-2014 20:30:19
70.197.196.83
 Re: what determins the length of the belt for running impliments in reply to Leroy, 01-15-2014 09:31:03
There ain't hardly a 2cyl Jd with a pulley 6" wide except maybe an H or a M. The B is wider than that & his R is definitely wider than 10", more like 14. most belts at our show are either 8 or 10" wide.
[Reply]  [No Email]
nlastovi
01-16-2014 07:54:25
67.208.179.138
 Re: what determins the length of the belt for running implim in reply to Gtx1967jewison, 01-15-2014 20:30:19
If I read the document correctly, University of Nebraska College of Agriculture measured thel R as a 9" pulley face (which I think means the width).
The 820/830 test says "Belt pulley diam. 12 7/32" face 9" rpm 1125 Belt speed 3599 fpm Belt flat Length 72' Width 7" Thickness 0.216""
http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=1091&context=tractormuseumlit
in comparison, the 520 test says "Belt pulley diam 9 11/16"
face 7 1/4" rpm 1325 Belt speed 3360 fpm Belt flat
[Reply]  [No Email]
Leroy
01-16-2014 07:32:42
69.88.207.185
 Re: what determins the length of the belt for running impliments in reply to Gtx1967jewison, 01-15-2014 20:30:19
Had 46 B, 49 B, 38 A, 51 A 7 50AR all only would take a 6" belt.
[Reply]  [No Email]
Mike M
01-15-2014 07:42:11
24.140.0.120
The old time JD pocket ledgers were full of info. I just can't remember if that info is in them ? Might be a good starting point in case no one chimes in with any old time rules of wisdom.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
