JD 5020 injector rubber hose
37chief
Location
California
There is a rubber sleeve over the end of the injector to connect the injector to by pass fuel to the tank. What is this rubber sleeve called? I can't find anything on the internet. If I had the correct name I probably could find the part. Thanks Stan
Do you think that if you had a set of them that were NEW on the shelf they could still be good after many years ? Don't know what kinda shelf life to expect from them ? I have a set of 6 here for emergencies but they are old.
Probably will be OK. They break down from fuel, possibly heat might add to breakdown.
