Another 530 reburbish question
Will the casting that holds the clutch brake assembly easily pull out of the frame. It is held by four bolts and it appears from the parts diagram that the forks and assembly will just slid out.
you will need to take the clutch leakage pin out first along with the four bolt on the front were the clutch break is.
