Yesterday's Tractor Co. New Parts for Old Tractors
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
jd b changing to 12 volt
superm1953
01-13-2014 12:15:31
69.11.166.70
my question is since the b we got is a mag tractor what all has to be changed to convert to 12 volt. can the generator be changed to charge 12 volt?
thanks
[Reply]   [No Email]
David G
01-13-2014 14:12:27
204.29.138.33
 Re: jd b changing to 12 volt in reply to superm1953, 01-13-2014 12:15:31
A delco alternator with integral regulator fits right up, why mess around with a generator and regulator.
[Reply]  [No Email]
Wilamayb
01-13-2014 13:59:16
164.144.248.26
The starter used on the late B is the exact same starer motor used on the 50 which was 12 Volts. It works fine. Mine has been on 12 Volts for at least 15 years with no issues.
[Reply]  [No Email]
machinery-man
01-13-2014 13:34:38
172.9.192.94
Just get a gen off an A plus 12v reg
[Reply]  [No Email]
John T
01-13-2014 13:24:09
173.133.2.159
I have used a 6 volt genny to charge a 12 volt battery simply by changing to a 12 volt Voltage Regulator HOWEVER before anyone has a calf, I'm NOT saying its proper or engineering correct or it charges at any high rate,, Im ONLY saying it can work........... Its best to have a genny shop change out the fields and do it right or just go get a 12 volt genny and 12 volt VR or else go the alternator route and change over to neg ground.
The 6 volt starter can still be used although it can be a bit tough on starter drives/gears. Best NOT to use a big heavy 12 volt battery, a lighter duty is less harsh on the starter drive.
If you change polarity the ammeter leads need swapped so it dont read bass ackwards, but if you stay with a genny Id stay at the original Pos ground
John T
[Reply]  [No Email]
Pete in MD
01-13-2014 12:33:40
71.245.164.148
12v battery
12v generator or convert old 6v generator
12v regulator
12v bulbs if it has lights
polarize generator before first startup
If changed to Negative ground switch wires at ammeter
[Reply]  [No Email]
superm1953
01-13-2014 12:35:15
69.11.166.70
 Re: jd b changing to 12 volt in reply to Pete in MD, 01-13-2014 12:33:40
how do you convert the generator?
[Reply]  [No Email]
Pete in MD
01-13-2014 13:03:42
71.245.164.148
 Re: jd b changing to 12 volt in reply to superm1953, 01-13-2014 12:35:15
Take it to a good starter/generator shop.
[Reply]  [No Email]
BushogPapa
01-13-2014 12:31:34
173.88.50.145
Really, about all you would need to do is put the 12V batter in place and change to 12 volt light bulbs (after you decide what generator or Alternator you will use).
That decision will determine if the system will remain positive ground or neg. ground.
12V is NOT necessary on a JD "B" and if you do want 12V I would recommend reducing the battery and ground cable size to reduce the amperage available to the starter. 12V will spin that poor starter super fast..
Ron.
[Reply]  [No Email]
Kent Petersen
01-15-2014 05:30:03
209.62.225.173
 Re: jd b changing to 12 volt in reply to BushogPapa, 01-13-2014 12:31:34
If you us the 6 volt starter it may spin the engine to fast for the imp on the mag to work make for hard starting
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
