Yesterday's Tractor Co. Compare our Prices For Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
5410 dragging brakes
Harry in Ky
01-13-2014 07:37:55
76.177.212.20
Anyone have any thoughts on some common problems that would cause the brakes to drag on 5400 series tractors? Could it be valve related or more likely internal issues with discs or pistons/seals?
[Reply]   [No Email]
JDGnut
01-14-2014 13:47:36
204.54.36.245
 Re: 5410 dragging brakes in reply to Harry in Ky, 01-13-2014 07:37:55
Like Jim said.. they have been a common problem.. you can try loosing the brake lines and see if they free up.. (this would indicate a problem with the brake valve.. 99.9% of the time.. this is not the problem..)
As Jim said.. Normally its the brake retractors.. weak/stuck/damaged.. causing the braking plate to not retract... There were also issues with the O-rings on the piston rolling or swelling and not allowing them to retract..
If you go in.. replace both... or some throw out the retractors..
[Reply]  [No Email]
Tx Jim
01-13-2014 08:30:04
69.35.160.117
JD 5000 series tractors have a history of springs(parts key #1) getting weak causing brakes to drag
[Reply]  [No Email]
Harry in Ky
01-13-2014 08:37:15
76.177.212.20
 Re: 5410 dragging brakes in reply to Tx Jim, 01-13-2014 08:30:04
Is it more likely just a weak spring problem or do the seals tend to swell and require more force to retract the pistons?
[Reply]  [No Email]
Tx Jim
01-13-2014 10:10:08
69.35.160.117
 Re: 5410 dragging brakes in reply to Harry in Ky, 01-13-2014 08:37:15
Failure history is springs not seals.
[Reply]  [No Email]
Tim S
01-13-2014 08:05:17
107.128.252.145
Loosen the bleed screws and see if that lets them free up...one side at a time...
[Reply]  [No Email]
Harry in Ky
01-14-2014 18:36:46
76.177.212.20
 Re: 5410 dragging brakes in reply to Tim S, 01-13-2014 08:05:17
I assume there would be no pressure to relieve by loosening the bleed screws, providing the brake valve is properly releasing when the pedal is up. At this point, I lean towards the springs being the problem, but will check the bleed screws before tearing into it.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
