isolate touch a matic problem on M
dieselade
Location
indiana
how do i isloate whether there is a problem with the touch a matic or a problem with the pump. mine wont do anything when i move the lever. it was ok a couple of years ago.
This is what was happening to mine when the pump seal was bad. I added new oil and it worked fine. Sat for a few weeks. Then was weak or would not work at all. Check your engine oil. If it is over capacity you will know the pump is draining back into the engine and the seal is no good.
