David,
If your solution worked for you it may well for me too. Could you explain the procedure in a little more detail so I may attempt the fix? I don"t want to start a fire by placing a wire in the wrong place. On my starter solinoid the top post is connected to the positive cable from the batteries, the bottom large connection goes from the solinoid to the starter case.(negative?) then there is a small screw connection that connects to a small wire. Thanks for your help!! You can Email me if you wish.
