Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Hard starting 466
12-23-2013 09:25:02
So the first question is always:
Is it smoking white when your cranking and it will not start?
If your not getting fuel it will not smoke white.
If your getting fuel and she is smoking white and not banging it is either a timing problem or a compression problem.
Heat and pressure. Compression ignition. All ether does is change the timing of the bang.
That is why in knocks so bad when you use too much.
12-23-2013 10:17:06
 Re: Hard starting 466 in reply to DanTheJDMan, 12-23-2013 09:25:02
The ether igniting and burning long before the piston is a TDC is the problem. Peak combustion chamber pressure is supposed to occur ATD.
