Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Relay wiring
12-23-2013 09:15:11
First of all we are not talking about apples and apples.
A 4255 is a Waterloo tractor............. This is not what we were talking about.
We were talking about the 2000 size not the 4000 size row crop tractors.
All the small 2000 tractors were modified from with the start soleniod in the field and if you look there is a seperate electrical section in addition to the original TM.
They drive you crazy because there are wires cut off and you think somebody has been in there jack legging some fix but it is the way they are supposed to be.
I'm not sure about the strart soleniod on the 4255. If it is a 4 pin it needs to be replaced with a 4 pin. These machine could use the tach for some logic. I know that the flashers for the turn signal and the hazard lights gets its (Flash) through the tach.
Tx Jim
12-23-2013 10:12:32
 Re: Relay wiring in reply to DanTheJDMan, 12-23-2013 09:15:11
Apples or oranges here is what you stated and is the reason in my asking if Waterloo tractors were included in your statement and I'll quote you. You didn't state all 55 series "UTILITY tractors"!
[/quote]All of the 55 series tractors were field modified with this kit mentioned above. \[/quote]
You also failed to explain how the start circuit on a utility tractor travels 3 different times through the fuse board!!!
Merry Christmas,Jim
