Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: help---removing throttle lever 420
Ohiotractorguy
12-22-2013 17:58:43
Another thing I have done is unbolt the bracket that mounts on the water/coolant pipe on top of the engine cylinder head (you will have to anyway to replace the friction disk on the inside). This will allow you to push the entire lever and rod assembly toward the rear of the tractor. . . from there you can heat up the ENTIRE part of the throttle handle that surrounds the shaft (there is a large portion that is inside the dash housing. I also try twisting the lever around on the rod to break it loose; you can also pull the throttle shaft forward like a slide hammer and the handle will be stopped by the dash casting. . . sometimes several pulls will loosen and separate the lever from the rod.
Copyright © 1997-2015 Yesterday's Tractor Co.
