TractorLinks.com
Show Parts for Model:
Re: Hard starting 466
cushman
12-22-2013 17:56:56
Thank all of you for your suggestions,this dozer has the fuel tank above the engine,so the fuel would not be draining away.When I checked the fuel pressure to the pump at 16psi at cranking speed, I assumed the operating fuel rail pressure was OK,was I correct?We could install a block heater,but it would require a generator to make it usable as this machine lives on a tile plow,and the owner would not like to cut and splice the tile each day to use the heater.I will try to get the owner to take a couple voltage tests to see if the voltage to the starter is week in the field at low temperature.B&D I would like more information on the starter you mentioned.
buickanddeere
12-22-2013 18:02:03
 Re: Hard starting 466 in reply to cushman, 12-22-2013 17:56:56
http://www.delcoremy.com/starter-models/44mt-heavy-duty-starter.aspx
Tx Jim
12-24-2013 03:46:11
 Re: Hard starting 466 in reply to buickanddeere, 12-22-2013 18:02:03
buickanddeere said: (quoted from post at 21:02:03 12/22/13)
b&d
Do you know the PN & price for the correct Delco starter for a 466 cid(7.6L) engine from the website you posted?? All I saw was starters for big truck engines.
Thanks,Jim
This post was edited by Tx Jim at 03:47:17 12/24/13.
buickanddeere
12-24-2013 07:59:27
 Re: Hard starting 466 in reply to Tx Jim, 12-24-2013 03:46:11
btw . Merry Christmas you crusty old cuss
Tx Jim
12-24-2013 08:59:55
 Re: Hard starting 466 in reply to buickanddeere, 12-24-2013 07:59:27
Merry Christmas/Happy New Year to you & your female BOSS. So is that how you state you don't know the PN & price of a starter for a 466??? :lol:
Hey I'm not crusty because I took my monthly bath this morning!!!!!!!!! :wink: That might be the POT calling the kettle black!!!!!!!!! :twisted:
buickanddeere
12-24-2013 07:58:07
Just match the bolt pattern, tooth count and tooth pitch. Starter are just about as a generic fit as socks.
