TractorLinks.com
Show Parts for Model:
Re: 2020 Diesel Timing
DanTheJDMan
12-22-2013 16:14:19
Just like he said. Take the little timing window plate off the pump and look in there when you put the pin in the flywheel. A 5/16 bolt about 4 inches long will work (REMEMBETER TO TAKE IT OUT) when your done. They make a plastic one now for that reason.
If there is only one mark your on #4 TDC. Turn the thing another 360 to get to #1. When the pin goes in the lines should be straight across form each other. It not loosen the pump and adjust. Always recheck turning the engine in the running direction.
D-
12-23-2013 10:51:54
 Re: 2020 Diesel Timing in reply to DanTheJDMan, 12-22-2013 16:14:19
It's a C pump.
