Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 2020 Diesel Timing
12-22-2013 15:15:23
Remove timing pin from left rear of engine near blowby tube and switch ends. TDC has dimple in flywheel and pin will locate as flywheel is turned slowly. NOT CRANKED!
Also a smaller but similar pin in base of pump.
Remove it and you can see a dimple in there. Dimple should be in center of hole.
Turn pump til centered. Back up flywheel then locate TDC again. Pump dimple should line up again.
12-22-2013 16:14:19
 Re: 2020 Diesel Timing in reply to D-, 12-22-2013 15:15:23
Just like he said. Take the little timing window plate off the pump and look in there when you put the pin in the flywheel. A 5/16 bolt about 4 inches long will work (REMEMBETER TO TAKE IT OUT) when your done. They make a plastic one now for that reason.
If there is only one mark your on #4 TDC. Turn the thing another 360 to get to #1. When the pin goes in the lines should be straight across form each other. It not loosen the pump and adjust. Always recheck turning the engine in the running direction.
12-23-2013 10:51:54
 Re: 2020 Diesel Timing in reply to DanTheJDMan, 12-22-2013 16:14:19
It's a C pump.
