TractorLinks.com
Show Parts for Model:
Re: Best way to remove 4020 head plug for block heater
jd_adict
12-22-2013 04:09:59
thanks alot for all the advise. the motor was just overhauled and runs like new. Its the front plug right by the alternator. A very sensative spot for stuffing in the torch. Today I am going to try a few techniques before the heat. Will let you all know how I make out.
D-
12-22-2013 07:39:24
 Re: Best way to remove 4020 head plug for block heater in reply to jd_adict, 12-22-2013 04:09:59
NO! Use the center plug. Don't heat the head. Heat the plug very hot as others said and let it cool on it's own. It will come out pretty easy.
Tim S
12-22-2013 08:29:55
 Re: Best way to remove 4020 head plug for block heater in reply to D-, 12-22-2013 07:39:24
D- got it right,,your heading for the wrong plug, Darn it,,and just to mention the fact that when you "are' heating some thing in a place where the heat can and will hurt things, get those "Things" off and out of the way "first",, it will help to keep your Dummy light from coming on.... The Old Timers would say to heat and cool a part like this 3 times,, and there seems to be some thing to it, the expansion the heat causes helps to loosen the piece ...
jd_adict
12-22-2013 18:11:15
 Re: Best way to remove 4020 head plug for block heater in reply to Tim S, 12-22-2013 08:29:55
Well guys I got the plug out. tried all the techniques before using heat and no luck. it was in there tight, impact wrench and hammer driver didnt budge it. so out come the torch. like I was told I removed the alternator and put tin in place for the injector lines to prevent heat damage. I heated the plug only till it was almost red around the hex area. put a big johnston bar and pipe on it and never even got to pull hard,.... plug was loose. I swear I did smell the lock tight melt loose. thanks for all the advise, bottom line is use a bit of heat. thanks
4020deereboy
12-23-2013 18:56:57
 Re: Best way to remove 4020 head plug for block heater in reply to jd_adict, 12-22-2013 18:11:15
Can you post a picture of the heater and how you are plumbing it in ?
Thanks Shaun
jd_adict
12-24-2013 15:34:53
 Re: Best way to remove 4020 head plug for block heater in reply to 4020deereboy, 12-23-2013 18:56:57
here is a pix of the way I am going to plumb my heater. This is not my tractor, seen it at a show and took the pix. My tractor has the new style injector lines and pump so the middle hole is not axcessible. but the plug right behind the alternator is, thats the one Im using. and will be very neat looking. I use the hole in the other side of the block center for the bottom of the heater. Hope this helps.
jd_adict
12-22-2013 18:15:45
Just wanted to add that I used the front plug because of neatness of hose. YES is should use the center plug to heat the head evenly with block heater. I have a few 4020s with it there and a couple with it in the front. thing is I may put a loader on it and dont want to be trying to change fuel filters with loader and heater hose in the way. thanks again
