TractorLinks.com
Show Parts for Model:
Re: Hard starting 466
buickanddeere
12-21-2013 15:41:19
Cranking rpm may have been a place to have looked after checking just the timing and a hydraulic pump de-stroker next. A 1/10 of a volt here, a 2/10 volt there and another 1/10 volt on high resistance connections and cables. Tired batteries, a worn starter and some extra drag from the closed center hydraulics. I have yet to ever have somebody report back with voltage across the starter while cranking. That one simple test tells a lot. Seems however everybody has $$$ instead to randomly throw parts at the problem. Pretty easy to drop 25-50 cranking rpm and loose cold weather starting ability. There is a right powerful Delco inline PM reduction drive starter that will wail that engine over. With rpms closer to idle speed instead of cranking speed. http://www.delcoremy.com/remy_44mt.html
Tx Jim
12-21-2013 16:08:41
 Re: Hard starting 466 in reply to buickanddeere, 12-21-2013 15:41:19
b&d
Does a IHC TD20C dozer have closed-center hyd's??
buickanddeere
12-21-2013 18:26:39
 Re: Hard starting 466 in reply to Tx Jim, 12-21-2013 16:08:41
Good point. Looks like a newer version of the IH crawler I ran as a teenager.
