Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Hard starting 466
DanTheJDMan
12-21-2013 15:06:03
Will it restart once you get it started? Does it rev way up until the governor wieghts pull the fuel rack off the magnet? Or does that engine have a rotary pump?
Top time the engine to make it start better cold. Just a little makes a big difference and in 4000 hours a little wear in the gears could make that difference.
I can't remember which way to make it top timed. but when you look through the hole in the timing gear cover to see the timing marks they should be straight across from each other as you turn the engine in the running direction and put the timing pin in the flywheel. What I can't remember is if the mark should be above or below the mark to be top timed. I would cheat up the width of the line. You know you are close or a little too far when you rev it up with no load and it flutters a little. It will sound great with a load but will flutter a little at high idle.
We got a bunch of 6410s in from Canada that all did that. They did start good cold and most people did not notice the flutter.
