Yesterday's Tractor Co. Compare our Prices For Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
help---removing throttle lever 420
old diesel
12-21-2013 10:55:16
207.144.124.18
the throttle lever will not stay up (idle) on (green) 420. friction disk completely gone, I have heated and driven roll pin out. I have heated lever very hot all around end of rod and area of roll pin still cannot drive rod out of lever. what am I doing wrong and what to do?
[Reply]   [No Email]
Ohiotractorguy
12-22-2013 17:58:43
75.107.155.66
 Re: help---removing throttle lever 420 in reply to old diesel, 12-21-2013 10:55:16
Another thing I have done is unbolt the bracket that mounts on the water/coolant pipe on top of the engine cylinder head (you will have to anyway to replace the friction disk on the inside). This will allow you to push the entire lever and rod assembly toward the rear of the tractor. . . from there you can heat up the ENTIRE part of the throttle handle that surrounds the shaft (there is a large portion that is inside the dash housing. I also try twisting the lever around on the rod to break it loose; you can also pull the throttle shaft forward like a slide hammer and the handle will be stopped by the dash casting. . . sometimes several pulls will loosen and separate the lever from the rod.
[Reply]  [No Email]
jd_adict
12-21-2013 16:45:10
216.46.151.14
I have removed a few of these and seems the best result is after you have heated around the rod on the throttle lever, use a hand held air hammer with almost the same sized punch that the rod is.
Make sure the air hammer punch is ground nice and flat so that it doesnt mushroom the end of the rod.
Safety first, dont forget the safety glasses. once you see it move, it will get easier. dont forget to check the roll pin hole after you get it apart. you may have to re drill it to size if it gets damaged . Hitting this rod with a hammer and punch just seems to bounce. Good luck
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
