4010 trouble
Anonymous-0
Hello. I've been having troubles with my 4010. it seems as if the the clutch is sticking. I put it in gear and it will creep along when I bring up the rpm it doesn't move any faster just rev up. In higher gears it wot go, or sometimes in reverse it gets stuck on frozen mounds. what can be causing, is the clutch sticking. the hydraulic oil is at safe.
The clutch is slipping... is there any "free travel" on the clutch pedal?
If there is, and it still slips, the clutch has failed, or POSSIBLY something is holding up the linkage or throwout bearing so the throwout bearing cannot back away from the clutch fingers.
Is it leaking engine oil from the rear of the engine? My 4320 was from the rear main , which was causing the clutch to stick. When I spiked the brakes it would release. It was real bad toward the end, new clutch and rear main later, all is good.
I have a 4320 that acted like that, turned out the clutch disk was warped, put new clutch in and it worked fine.
