Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 3020 hydraulics
buickanddeere
12-13-2013 19:16:58
Instead of re-working/rebuilding/replacing the dash hydraulic valves on an early tractor? Could it be simpler and more cost effective to install a standard joystick loader control for the loader boom & bucket? There is no mention of a cab to complicate the installation.
NY 986
12-14-2013 06:17:49
 Re: 3020 hydraulics in reply to buickanddeere, 12-13-2013 19:16:58
Yeah, but he may want to square that remote away for when it is used on other jobs where he does not want the cylinder to move once set.
buickanddeere
12-14-2013 07:48:44
 Re: 3020 hydraulics in reply to NY 986, 12-14-2013 06:17:49
I'm not sure what you are getting at. Who would supply a joysticks from a worn out rear scv and tie it up? When a couple simple T's will connect the joystick. Which leaves the scv's open for other implements. And don't incur the cost or rebuilding old scv valves or worn scv couplers.
This post was edited by buickanddeere at 07:50:08 12/14/13.
NY 986
12-14-2013 08:01:49
 Re: 3020 hydraulics in reply to buickanddeere, 12-14-2013 07:48:44
Quite simply if the tractor is used on other implements and uses that remote circuit there is the possibility of the cylinder creeping unintentionally. It happened on our 4010 running a 347 baler that had hydraulic hitch shift and positioning of the 30 ejector. It has nothing to do with the joystick you are talking about.
buickanddeere
12-14-2013 08:54:01
 Re: 3020 hydraulics in reply to NY 986, 12-14-2013 08:01:49
What cylinder creeping unintentionally? The loader is controlled via the joystick. Implements on the scv's have nothing to do the the loader circuit.
