Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: John Deere H clutch
Mark Poss
12-13-2013 12:09:26
I would swap the whole pulley if I could find one that was not wore out. I have talked to two other H owners at tractor shows and they told me that their clutches do not snap in either.
Mike M
12-13-2013 12:41:33
 Re: John Deere H clutch in reply to Mark Poss, 12-13-2013 12:09:26
Make sure your left hand cam bearing which is a ball bearing is not loose or shot completly.This controls the camshaft end play. Most all H's I have came accross (and that's plenty) need one.
If you are near Ashland Ohio bring it over and we can look at it and swap some parts onto it.
Mike(NEOhio)
12-14-2013 07:49:07
 Re: John Deere H clutch in reply to Mike M, 12-13-2013 12:41:33
Hi Mike,
Do you know the actual bearing number for that left camshaft bearing. JD7169R is part no. What I looked up came out to be 6305-J. Is that correct? I bought my H 30+ years ago but the left bearing was shot. I replaced it with a motor bearing the same size but it didn't hold up well. I think it should be a deep groove type to take the thrust from the cam gear. That bearing was so bad that it damaged the timing gears, governor bearing, fan gears, cams and lifters. I was young and didn't know much about Deeres when I bought it.
mike m
12-14-2013 09:08:00
 Re: John Deere H clutch in reply to Mike(NEOhio), 12-14-2013 07:49:07
I have replaced several but not sure about it but I bet most I stuck in a common bearing. As to holding up I don't know? Most likely don't get ran that much.
Copyright © 1997-2015 Yesterday's Tractor Co.
