I have two issues which may be connected. Background: it"s 13 degrees here (MN). The hydraulic fluid is at the correct level.
1. 46A loader will keep going up even if lever is released to the neutral position. The bucket isn't affected. It usually happens if I lift the loader and want it to stop-it keeps going up. It has happened a few times when warm, but today it was constant.
2. The lever for the back blade was stuck (locked) in the down position and would not release. That is the first time this has happened. I pulled off the cowling and gave the pivot points a little WD40. Tapped it with a hammer and the bottom of the lever broke off. I really didn't hit it that hard.
Thanks in advance for your help.
