TractorLinks.com
Show Parts for Model:
Re: 4030 steering motor got sn
Tim S
12-13-2013 07:07:47
Remove the steering wheel ,lower hoses and the hinge bolts and drop the valve down out of the dash (leaving the dash in place),check the plastic bushing in the column and the thrust bearing as you lift the column off the steering metering pump (leave 2 of the bolts in the metering pump so as not to disturb the lower part, it won"t need attention)there is one seal that will be exposed that is the one that is leaking "but" if the thrust bearing and plastic bushing is worn it lets the shaft work up away from the seal, and even a new seal will leak...
Mitch D
12-13-2013 09:41:58
 Re: 4030 steering motor got sn in reply to Tim S, 12-13-2013 07:07:47
Okay thanks Tim
