Show Parts for Model:
Re: 3020 hydraulics
Tx Jim
12-13-2013 04:39:21
If I'm understanding you correctly the loader is operated from the rear hyd breakaway couplers??
Hyd filter is on LH side under battery, Screen(parts key #8) is located between filter and rear axle trumpet. Trans needs to be drained to check/clean screen or put a running shop vacuum hose in hyd oil filler opening.
AR75603 Filter Element ADD 7.96 USD
This is the A&I part number for the rockshaft control cable that you can get some JD dealers to furnish.
A-AR26810 Rockshaft ADD 91.11 USD
OR the JD PN
AR26810 Push Pull Cable ADD 131.00 USD
This post was edited by Tx Jim at 09:09:08 12/13/13 2 times.
