TractorLinks.com
Show Parts for Model:
Re: Early '35 John deere A oil pressure
elkcagg
12-12-2013 19:19:25
Fixing this problem can be challenging. First thing I"d check is oil level. Make sure those oil pump gears on left side of crankcase are submerged as it may have lost its prime. If your oil pump gears are worn that can make it hard to get pressure as well. I bought my oil pump gears from Detwilers 4 years ago for $100 a set. Make sure oil suction pipe from bottom screen to oil pump isn"t cracked. (This pipe runs horizontally) Also, make sure your oil filter canister isn"t cracked or smashed from over tightening the filter nut, or has small pin holes. Mine had small pin holes nearest the casting wall from mouse urine. If its smashed from over tightening then the canister has to be removed & straightened. I"m assuming your tractor had been recently running? If so, get the oil level to flywheel side by jacking right side of tractor to submerge the oil pump gears for starters or add 2 or 3 quarts of oil. Some guys park them with right wheel higher for this reason. The oil pressure stick should raise while you hand crank the motor.
