TractorLinks.com
Show Parts for Model:
Re: 3020 hydraulics
buickanddeere
12-12-2013 16:34:57
Loader works better on it's own joystick. With the oil supply tapped into the line supplying the SCV's. The rear scv's are best left for lifting cultivators. The loader oil returned to the transmission filter via the rockshaft oil return line. Or a ported filter cover.
Dennis430
12-12-2013 17:07:11
 Re: 3020 hydraulics in reply to buickanddeere, 12-12-2013 16:34:57
Over my head; is there a filter I should change? It sounds like need a new cable for the rear hydraulics,
Tx Jim
12-13-2013 04:39:21
 Re: 3020 hydraulics in reply to Dennis430, 12-12-2013 17:07:11
If I'm understanding you correctly the loader is operated from the rear hyd breakaway couplers??
Hyd filter is on LH side under battery, Screen(parts key #8) is located between filter and rear axle trumpet. Trans needs to be drained to check/clean screen or put a running shop vacuum hose in hyd oil filler opening.
AR75603 Filter Element ADD 7.96 USD
This is the A&I part number for the rockshaft control cable that you can get some JD dealers to furnish.
A-AR26810 Rockshaft ADD 91.11 USD
OR the JD PN
AR26810 Push Pull Cable ADD 131.00 USD
This post was edited by Tx Jim at 09:09:08 12/13/13 2 times.
