John deere 950 float problem
Blue healer
New User
I have a John Deere 950 utility tractor with the 423 front blade on it ( the blade is new to me this winter ), when I have it in float and try to angle my blade down pressure is applied to the blade as it angles. Any ideas on what is causing this? control valve problem..?
After a ton of research and no answer I stopped In to the dealer and found a service guy willing to listen and spend some time with me we pulled the service manual and found this to be normal when in the float position , the manual said not to use ( raise or lower ) the 3pt or other cylinder when in the float position or pressure will be Applied to the float cylinder
