Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
4030 steering motor got sn
mitch d
12-12-2013 16:07:20
72.160.222.68
Hey guys went to his farm today and the sn is after the break 0118xx. So...how bad of a job is it to fix the leak?
[Reply]   [No Email]
Tim S
12-13-2013 07:07:47
68.75.30.50
 Re: 4030 steering motor got sn in reply to mitch d, 12-12-2013 16:07:20
Remove the steering wheel ,lower hoses and the hinge bolts and drop the valve down out of the dash (leaving the dash in place),check the plastic bushing in the column and the thrust bearing as you lift the column off the steering metering pump (leave 2 of the bolts in the metering pump so as not to disturb the lower part, it won"t need attention)there is one seal that will be exposed that is the one that is leaking "but" if the thrust bearing and plastic bushing is worn it lets the shaft work up away from the seal, and even a new seal will leak...
[Reply]  [No Email]
Mitch D
12-13-2013 09:41:58
184.158.39.85
 Re: 4030 steering motor got sn in reply to Tim S, 12-13-2013 07:07:47
Okay thanks Tim
[Reply]  [No Email]
WTW
12-12-2013 17:10:09
204.12.185.249
mitch, If your mechanic isn't a big fat guy you can lay on cab floor or operators platform and replace this leaking seal. The late steering pump design can be left connected to the hoses. Four of the six 3/8" bolts can removed from it to lower metering pump from steering column bracket. The soft seal can be then replaced with your fingers.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
