paint lettering on radiator
37ar
so how do you gentlemen paint the yellow lettering on your radiator? got any advice or tricks to make this easy and look good. thanks
I use a cheap 1" foam brush. Put a little on the brush, then apply to the letters. It helps to dab it on, instead of using brush strokes.
(quoted from post at 16:01:19 12/12/13) I use a cheap 1" foam brush. Put a little on the brush, then apply to the letters. It helps to dab it on, instead of using brush strokes.
That is how I do it also.
Use a heavy peace of card board,Put a heavy coat of paint on it and dab it on the casting.
It may take a 2 or 3 coats.
I used a finger-nail polish brush. Took 2 coats but looks great. Takes time, but you're putting more of "yourself" into a tractor you will take pride in!
