260 loader - Need relief valve information
I've got a 260 loader that someone removed the factory relief valve (actually its a cross over relieve valve with a case drain) from. I'm trying to find a replacement. Could one of you out there who has a 260 loader please take a close look at the relief valve that is mounted to the right side of the loader frame. IT will be a little block with 5 lines coming out of it and it will be plumbed between the directional control valve and the cylinders. I'd like to know if there's any numbers on the valve or a manufacturers name. Deere wants over $1000 for that part. I can plumb it using other components but I'd like the factory equivilent if possible.
Here's the specifications of the only RELIEF valve I can find still available for a model 260 FEL
