TractorLinks.com
Show Parts for Model:
Re: 3010 Zenith Carb Idle Problem?
WTW
11-19-2013 18:17:06
These carburetors will run rich when they become worn in the accelerator piston and bore. You can replace the piston but the bore is what it is and may be worn too large to correct. DW
Texasdeere
12-08-2013 15:01:32
 Re: 3010 Zenith Carb Idle Problem? in reply to WTW, 11-19-2013 18:17:06
I think the piston and bore might be the culprit here. I talked with a guy that rebuilds these things. Said you should be able to kill the engine at idle by turning the idle mix screw all the way in. He also said any fuel leaking by the piston inside this carb will drive you crazy trying to figure out what is going on. Sorry but I still haven't had any time to mess with it other than verifying that the choke is full open.
