Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Don't Use E15 Gas
Mike Aylward
11-19-2013 10:46:29
In case you don't remember, regular gas can destroy diaphragms, too. Most diaphragms go bad because of one of two things: either they are old or were improperly installed. As far as ethanol absorbing moisture it is true but only to a point. It only absorbs what is already in the gas. Remember using "Heet" or some such other product to keep your fuel lines from freezing in the winter time? That is nothing but METHANOL which is MUCH more harmful than ethanol will ever be. It DOES corrode in and of itself. Ethanol absorbs the moisture that is ALREADY in your gas and allows it to be burned and gotten OUT of your fuel system so it DOESN'T cause rust and/or corrosion. Most of the propaganda put out on these things are from the oil and/or additive companies who are only preying on the "fears" of people. Ethanol is a good product that I have used for over 35 years with no problems whatsover. It has been used on my farm in everything from a chain saw, a parade tractor to hard working farm tractors. No problems whatsoever in 35 years. NONE. In fact, I have LESS fuel problems now. Mike
Copyright © 1997-2015 Yesterday's Tractor Co.
