TractorLinks.com
Show Parts for Model:
Re: 70 ign problem update
Bob Harvey
11-18-2013 16:22:18
Beg to differ. A 'reducing' resistor does just that with in a second or less, a 'Ballast Resistor' slows down the process with the use of a longer (lengthwise) wire coil, hence a slower response to the loss of energy that goes to the starting system = more juice to the coil/points system during starting. Seems to me the # series had that system hard wired into the "Ignition switch".
John T
11-18-2013 16:32:40
 Re: 70 ign problem update in reply to Bob Harvey, 11-18-2013 16:22:18
Yep I think the 720 etc had the stand alone discrete white ceramic bathtub style of ballast resistors while the new generation had more like a wire link or fusible link looking thermistor on the ignition switch that acted more like the resistor/thermistors you described. My answer covers the old style two cylinder tractors with more of a fixed resistance voltage dropping current reducing ballast which isn't the same as what you're describing. I think youre more right for new generation and Im more right for the old two cylinder tractors.
Very fun chattin with ya, thanks for the info
John T
Bob Harvey
11-18-2013 16:48:40
 Re: 70 ign problem update in reply to John T, 11-18-2013 16:32:40
Right back at ya. My limited knowledge of the subject is based on the 2 'N' Ford's I had. My '60' has a resistor as part of the 'ignition' sw., but I think it has to do with the lights.
John T
11-19-2013 05:05:01
 Re: 70 ign problem update in reply to Bob Harvey, 11-18-2013 16:48:40
Youre right, many brands of tractors with that wire coil resistor on the ign/light switch THATS A LIGHT DIMMING RESISTOR.
Many other tractor light/ign switches have TWO RESISTORS on the switch. One (flat wound) is the generators field current limiting resistor for Low or High charge on tractors that used a cutout relay NOT a Voltage Regulator and the other coil of wire/resistor is for light dimming.
The older two cylinder Deeres (720 etc) used a stand alone discrete fixed bathtub style ballast ignition resistor and and a start by pass system so the coil got battery voltage while cranking but reduced (6 volt) when running.
Some of the 12 volt New Generation Deeres (that used a 6 volt coil) had a thermistor/resistor type device on the switch or wired to it (looks like a wire fuse link etc) AND THERE WAS NOOOOOOOOOO START BY PASS NEEDED because the resistance was low for starting but when it warmed up its resistance increased so the coil only saw 6 instead of the closer to 12 volts at starting. I THINK THATS THE TYPE OF DEVICE YOU ARE THINKING OF
Whewwwwwwwwww got all that lol post back an questions
John T
