TractorLinks.com
Show Parts for Model:
Re: 70 ign problem update
John T
11-18-2013 13:26:39
For a 12 volt tractor the coil can be EITHER:
a) A full true 12 volt coil NO BALLAST REQUIRED
b) A 6 volt coil if you add a series in line voltage dropping (12 to 6) current reducing ballast resistor.
c) A coil labeled "12 volts" or "12 volts NOT for use with ballast or no ballast required" is intended for a 12 volt tractor and requires no ballast.
d) A coil labeled "6 volts" or "12 volts for use with or requires ballast resistor" IS A 6 VOLT COIL
John T
