TractorLinks.com
Show Parts for Model:
Re: 4040 john deere
Tim S
11-18-2013 12:58:11
Some times #30 check valve leaks pressure past and gives a bit of a Hydraulic lock,this would give you the easy steer as you start up then getting harder afterwards..and the thrust bearing in the column needs looked at when you have it apart like Tech7 stated..
triston
11-19-2013 12:02:06
 Re: 4040 john deere in reply to Tim S, 11-18-2013 12:58:11
thanks for the help everybody
Tim S
11-19-2013 12:32:15
 Re: 4040 john deere in reply to triston, 11-19-2013 12:02:06
When you get into the steer motor get back with use for help getting that ornery pin out that hooks the pistons together and timing the pinion...
