TractorLinks.com
Show Parts for Model:
Re: 4040 john deere
Tech 7
11-18-2013 10:14:13
Tx Jim might post a page from the parts catalog to help us out, but until then I would check up in the steering column above the hand pump. There is a thrust bearing in the steering shaft that will disintegrate and make the steering tough. I have seen this a few times.
Tx Jim
11-18-2013 11:37:37
 Re: 4040 john deere in reply to Tech 7, 11-18-2013 10:14:13
Tech 7 said: (quoted from post at 13:14:13 11/18/13) Tx Jim might post a page from the parts catalog to help us out, but until then I would check up in the steering column above the hand pump. There is a thrust bearing in the steering shaft that will disintegrate and make the steering tough. I have seen this a few times.
Tech 7
I know that you're trying to get me reprimanded for posting too many parts photos. :wink:
This post was edited by Tx Jim at 11:45:15 11/18/13.
triston
11-18-2013 15:47:52
 Re: 4040 john deere in reply to Tx Jim, 11-18-2013 11:37:37
I just found out from the owner of the tractor that they have put 3 complete steering columns on it with no change,they all acted the same way. So i dont think its anything to do with the column and I put my valve with all my fittings on it this morning and that helped alot. It had several places that acted like it was sticking when you was turning the steering wheel. Now with my valve on the tractor it is no longer doing the sticking and is a 100% better it just doesnt steer as easy as it should especially when you force the steering wheel. Wondering what you guys think about the back pressure piston in the front steering motor? Is there any way to check for that? Or what would be any symptoms for the back pressure piston failure?
Tim S
11-18-2013 16:20:57
 Re: 4040 john deere in reply to triston, 11-18-2013 15:47:52
What is the stand by pressure ??,,and yes the steer motor could be causing the problem,,,If all else has been tried,, that's where I would go next....
Tim S
11-18-2013 12:58:11
Some times #30 check valve leaks pressure past and gives a bit of a Hydraulic lock,this would give you the easy steer as you start up then getting harder afterwards..and the thrust bearing in the column needs looked at when you have it apart like Tech7 stated..
triston
11-19-2013 12:02:06
 Re: 4040 john deere in reply to Tim S, 11-18-2013 12:58:11
thanks for the help everybody
Tim S
11-19-2013 12:32:15
 Re: 4040 john deere in reply to triston, 11-19-2013 12:02:06
When you get into the steer motor get back with use for help getting that ornery pin out that hooks the pistons together and timing the pinion...
triston
11-18-2013 10:27:54
it steers fine as long as your easy with the steering wheel,if you had to make a turn real fast is when it gets hard.A friend of mine said he had the same problem an just took the metoring pump apart and put it back together with new gaskets and it was fine after that
