Anonymous-0
JD model B overhauled engine 6 months ago ,the following work was done,cylinders checked for crack . ok rebore cylinders .090 new pistons ,rings, cylinder head checked for cracks ok ,resurface, new guides valves and seats .new piston pin bushing fitted., oil pump overhauled new radiator core ,carb and mag overhauled, engine assembled and ran for 2 hours and put in storage.6 month later tried to start engine stuck checked and removed head, .anti freeze in both cylinder and in crankcase .coolant was found in cylinders above the rings only, any ideas Thanks
