Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 1967 4020 Main Hydraulic Pump
Tx Jim
11-10-2013 08:35:18
There are 8 each of the inlet & outlet valves. Setting stroke control valve requires a 3000# gauge and adjust on tractor with engine running.
11-10-2013 10:39:26
 Re: 1967 4020 Main Hydraulic Pump in reply to Tx Jim, 11-10-2013 08:35:18
Again, thanks for your response. See the page attached. The valve on the left I believe is the stroke control valve and it is adjusted based on the pressure the pump develops as you said. The valve on the right is my concern, from this page I understand it needs adjustment as well. What can you tell me to adjust this valve. I am thinking I will go to the dealership and see if I can borrow JDH-19. What have you done to adjust this valve in the past? Paul
Tx Jim
11-10-2013 11:11:09
 Re: 1967 4020 Main Hydraulic Pump in reply to 2510Paul, 11-10-2013 10:39:26
Sorry but TOO much water has run under the bridge for me to remember. Maybe Tim,Tech 7,Cliff or someone else will help you.
This post was edited by Tx Jim at 11:11:51 11/10/13.
