TractorLinks.com
Show Parts for Model:
Re: 855 3 point hitch won't go down
leon
11-10-2013 04:47:30
What do you mean, rear pto strained? Is the hitch rate-of-drop valve that's located under the seat turned CCW to the open position?
Jon Marino
11-10-2013 05:38:33
 Re: 855 3 point hitch won't go down in reply to leon, 11-10-2013 04:47:30
Yes, I have messed with the knob a lot, CCW, CW, and everywhere in between.
Jon Marino
11-10-2013 05:35:42
When I use my tiller, and it has a slip clutch, gets in hard dirt. When I use my rotary cutter, it has a shear bolt, in heavy fescue. I can hear the engine pull down. Then the 3 point hitch will not go down, up works fine.
The first time it happened, I was tilling and the slip clutch did not slip (it had been a while since I used it and it was stuck together) and the tractor almost died when I hit a root. I got it out of the root, raised it up and it would not go back down.
