TractorLinks.com
Show Parts for Model:
Re: PTO shaft to mower stuck on tractor
Tx Jim
11-10-2013 04:07:50
If your yoke is similar to the one in parts schematic I would GUESS one needs to remove spring(parts key#2) to get pin to release.
Dave Register
11-10-2013 06:43:55
 Re: PTO shaft to mower stuck on tractor in reply to Tx Jim, 11-10-2013 04:07:50
Tx Jim,
Thank you for taking the time to include the parts drawing, truly appreciated.
The pin your drawing shows is the one I removed.
As this pin only went approximately 2/3's of the diameter of the shaft I am wondering if it does have balls in it that keep the PTO on the tractor shaft, as suggest by "Bob". I will investigate the further and let everyone one know if there are balls inside the coupling. Thanks,
Dave.
Tx Jim
11-10-2013 07:21:20
 Re: PTO shaft to mower stuck on tractor in reply to Dave Register, 11-10-2013 06:43:55
I've never seen the type you have but normally if your yoke had balls they would be shown in photo I posted. I suggest to disconnect the mower and pull tractor away far enough so telescoping shafts slide apart to eliminate binding of shafts.
Dave Register
11-10-2013 07:45:40
 Re: PTO shaft to mower stuck on tractor in reply to Tx Jim, 11-10-2013 07:21:20
Tx Jim,
Thanks for the suggestion, I will do what you reommend and see if it will come off. Thanks,
Dave
