TractorLinks.com
Show Parts for Model:
Re: PTO shaft to mower stuck on tractor
Bob
11-09-2013 19:45:19
"Twist release" would imply a system where 3 captive steel balls retain the yoke. Yet, you have a pin. I am confused.
Dave Register
11-10-2013 06:31:03
 Re: PTO shaft to mower stuck on tractor in reply to Bob, 11-09-2013 19:45:19
Hi Bob,
When the twist release quit working, I took a cold chisel and split the ring which was hard plastic. With the ring removed there was a spring loaded pin under the ring. I can only surmise the ring,when turned, depressed the pin to release the PTO. I used the spring loaded pin to release the shaft about 10 times (it was very diffcult to press down with my thumb)before it stuck, that is when I pulled the spring off the pin and the pin fell out. Still would not release.
Thanks, Dave
