TractorLinks.com
Show Parts for Model:
Re: 3020 light switch
55 50 Ron
11-09-2013 17:12:43
Tx Jim and Bob,
Hope I didn't create a problem for you. This 3020 is a gas tractor and has 12 volt electrics.
The switch which you kindly posted has more terminals than on the new switch I have for the 3020 12v gasser.
The JD Parts Catalog from JD website gave switch part number AR 28401.
This switch has 6 terminals B (assumed battery), HD1, HD2, FL, TL, R2 and the dimming resistor.
The old switch (which tested bad) also had 6 terminals. There were broken wires for the FL and TL of the old switch and from what I can tell, nothing connected to the R2 terminal.
However, I'm still curious as to what R2 is for. Thanks for your inputs.
long green line man
11-09-2013 17:52:34
 Re: 3020 light switch in reply to 55 50 Ron, 11-09-2013 17:12:43
Ron: FL ter.is black wire to rear food lamp, TL ter. is red wire to rear tail [red] lamp. With 4 light fender lamps you won't need resistor; on new switch.. White wire to rear outlet socket , connects dir. to battery or wire going to B ter.on switch...
