Dave Register
New User
I have a 1998 5410 John Deere with a 1018 John Deere mower. The mower's pto shaft is stuck on the tractor's shaft and won't come off.
The original twist release broke. So then I had to hold down the pin to uncouple the PTO shaft from the tractor. Then the mower pto stuck on the tractor's shaft and won't come off, at that time I broke the spring on the pin and remove the pin thinking that would release the shaft. The pto will slide back and forth about 1/4" but comes to a hard stop when moved forward or backwards.
Does anyone have an idea what I need to do to remove the pto shaft??
