Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 3020 light switch
Tx Jim
11-09-2013 09:13:50
Ron
It's been several years since I looked at the backside of a 24 V light switch but the "R" would indicate rear light.
Bob
11-09-2013 09:56:38
 Re: 3020 light switch in reply to Tx Jim, 11-09-2013 09:13:50
Actually, in this case it DOESN'T mean "rear". It marks the terminal next to the headlamp dimming "R"esistor, and is used to power certain lights, at certain switch positions, depending on if there's two or four headlamps.
Here's a schematic from a 4020 SM, which I would ASSUME is similar in this respect to a 31020. In the 4020 manual, at least, it's only shown used with 24 Volt diesels in certain configurations.
This post was edited by Bob at 11:10:40 11/09/13 2 times.
Tx Jim
11-09-2013 10:49:11
 Re: 3020 light switch in reply to Bob, 11-09-2013 09:56:38
This post was edited by Tx Jim at 10:52:00 11/09/13.
Bob
11-09-2013 11:10:10
 Re: 3020 light switch in reply to Tx Jim, 11-09-2013 10:49:11
I had to edit my post, as the schematic didn't post the first time.
Can you remember at what switch positions the "R2" terminal is powered vs. the "HD2" terminal?
Tx Jim
11-09-2013 11:41:48
 Re: 3020 light switch in reply to Bob, 11-09-2013 11:10:10
I still think R2 powers the rear light
but I'll need to do some more thinning.
This post was edited by Tx Jim at 11:43:09 11/09/13.
Bob
11-09-2013 12:01:19
 Re: 3020 light switch in reply to Tx Jim, 11-09-2013 11:41:48
Rear/warning light is "TL".
"R2" is on opposite end of dimming resistor from "HD2".
("R1" is on opposite end of dimming resistor from "HD1".)
Tx Jim
11-09-2013 12:11:52
 Re: 3020 light switch in reply to Bob, 11-09-2013 12:01:19
Bob said: (quoted from post at 15:01:19 11/09/13) Rear/warning light is "TL".
OK Rear/warning light is "TL" now tell me what powers the "white work light" IE the black wire if it's not the R2? I don't have that flavor service manual.
This post was edited by Tx Jim at 12:15:26 11/09/13 3 times.
Bob
11-09-2013 12:15:29
 Re: 3020 light switch in reply to Tx Jim, 11-09-2013 12:11:52
OBLIVIOUSLY, R2, which is shown connected to the outer FRONT lights as well, in the diagram I posted where "R2" is used. (Wire #5, Green.)
Tx Jim
11-09-2013 12:19:05
 Re: 3020 light switch in reply to Bob, 11-09-2013 12:15:29
Then I guess you're admitting that my first statement(It's been several years since I looked at the backside of a 24 V light switch but the "R" would indicate rear light.) is correct.
Bob
11-09-2013 19:42:01
 Re: 3020 light switch in reply to Tx Jim, 11-09-2013 12:19:05
Yep, Jim, I concede. It's hooked to TWO front lights and ONE rear light, but, obviously, as you state, the majority DOESN'T rule and it feeds the rear lights (actually one LIGHT).
