TractorLinks.com
Show Parts for Model:
Re: PojwerTrol Pump Seal
Bob
11-09-2013 08:19:38
IMHO, original seal #AR613R was a WIDE double-lipped seal. Replacement, #AF2167R is a NARROW (.256") seal and you would use TWO, installed back-to-back, with the lips each facing OUTWARD.
That's the case with the power steering pumps, etc..
Pete in MD
11-09-2013 19:42:40
 Re: PojwerTrol Pump Seal in reply to Bob, 11-09-2013 08:19:38
Bob,
On the original double-lipped seals didn't one lip keep oil in the pump and the other lip keep the pump from sucking in air?
If that's the case, when using 2 single-lip seals shouldn't the lip of the inner seal face the pump side and the lip of the outer seal face away from the pump?
Bob
11-09-2013 20:28:36
 Re: PojwerTrol Pump Seal in reply to Pete in MD, 11-09-2013 19:42:40
I believe that's the way the lips on the original double-lipped seals were made... the lips and garter springs faced outwards.
Installing the new ones that way allows for a little grease to be packed between the lips for startup lube and works just fine.
